Rim lock...
Old 12-15-2006, 03:03 PM
Default Rim lock...
What size are the wheels i cant remember, and im going to order my tires today and i want to get the rim locks...
DUNLOP D606 90/90-21 FRONT
DUNLOP D606 120/90-18 REAR
these sizes are right, right?
ALLOY RIM LOCK 1.60
ALLOY RIM LOCK 1.85
ALLOY RIM LOCK 2.15
ALLOY RIM LOCK 2.50
which size do i want? i thaught our rear tire was wider than 2.5"???
Old 12-15-2006, 03:36 PM
jsac's Avatar
Default RE: Rim lock...
ok dumb question.... what purpose do the rim locks serve?... i just bought a set of kenda trakmasters and will have them popped on in a week or so, are these something i need?
Old 12-15-2006, 03:38 PM
if you run low pressure, the keep the tire from spinning on the wheel and ripping out the valve stem... makes for a flat tire....
Old 12-15-2006, 05:26 PM
Ok i found in a earlier post that 1.85" rim lock is for the back?
I can tell i have been around here awhile, because most of the questions i ask anymore are kinda complicated and noone knows the answer to them..... damn the bad luck... anyone? can anyone help?
Old 12-15-2006, 05:55 PM
Kawi Wawi's Avatar
I have heard in a few places that it's 1.65 on the front and 1.85 on the back.
Sounds small, but I think that's right.
Old 12-15-2006, 06:30 PM
I can't remember the exact value of the top of my head, but the size you need is stamped on the rim itself.
Old 12-15-2006, 06:44 PM
i guess ill be waiting to order them... thanks...
Old 12-15-2006, 09:12 PM
ol guy's Avatar
Location: Kennewick Washington, in the washington desert
The shop manuel says the rim sizes are 21x1.60 and 18x2.15. Dennis kirk part # for the 1.60 is 51-3549 and the # for the2.15 is 51-3551 those are from parts unlimited. the catalog also has some from motion pro for less money. hope that helps
Old 12-15-2006, 09:13 PM
YYY.GUY's Avatar
ORIGINAL: Kawi Wawi
Yep, those are the sizes I wrote down. I don't recall where I got them, but it sounded authoritative enough that I put it down in my KLX shopping list. The 1.85" was easy to find, but still haven't been able to locate the 1.65".
Rim Locks, Front 1.65"
Rim Locks, Rear 1.85"
Also, I haven't found spoke weights anywhere to balance the addition of the rim locks. I've seen them on bikes, but not in any catalogs. I guess I'll have to check next time I'm at the dealer. (And let's not start anything again about "spoke nipples", ok?)
Mike
Old 12-15-2006, 10:38 PM
ORIGINAL: ol guy
so do you get rim locks size 1.6 and 2.15? is 1.85 too small?
Quick Reply: Rim lock...
