Rich or Lean: how to remember
I know that lean is caused by more air but I will forget that in 3 weeks. I need a mnemonic or is that nmeonic? that will help an ex-Mensa member remember whether lean is caused by more air or more gas. The only saying I can remember is :"You can't be too rich or too lean", and that doesn't help.
You've obviously never had a bike where the main jet came unscrewed and was lying in the bottom of the float bowl. There's such a thing as too rich.
When black smoke comes out of the exhuast, you're running too rich. When the pipes glow cherry red, you're too lean. Rich mixture gives more fuel per amount of air. Lean mixture gives less fuel per amount of air. The magic number to go by is 14.7 to 1 (14.7:1). So for every 1 lb of fuel to burn, it would need 14.7 lbs of air.
Its also like cooking steaks. Too lean of meat makes for a more chewy steak, not very appertize. A more fat rich steak makes for a tender meal. Too much fat rich steak, and you'll be wasting the fat by cutting it off.
