Reuse head cover gasket?
I have the tank off for my new-to-me 2007's free/cheap mods installation.
It's just sitting there wide open, so thought I might check valves while I'm in there.
Can I reuse the head cover gaskety? Looks like it's a nice convenient rubber version - and I'm sure it's never been off. Is it typically good for a reuse or two or should I pick up a new one prior?
Either way, adhesive or no? I've seen it both ways with rubber gaskets.
TIA
TIA
Yes, you can/should definitely reuse that gasket. It was only a problem on some/all '09 models that had a funky rubber compound that seemed to shrink when you tried to reuse them. I have an '06 with several valve checks and many, many thousands of miles on it, and the original gasket still works perfectly. Unless yours has visible damage or a tear, use it.
Do you mean a font like Wingding???
JK , TNC is pretty smart.
One other thing, You should use sillicone on the gasket where the half moons dip down on the side of the head (the cam journals) .
Originally Posted by jeffzx9
Permatex "Right Stuff." EXCELLENT for head/valve cover gaskets.
Just a finger-smoothed bead is all you need.
Oh, wait a minute...I see you're referring to that Permatex product. I don't know enough about that sealant. If it's silicone based I'd say it will be fine. Otherwise, no experience with it from me.
