Reshaped My Side Panels
Old 10-05-2011, 02:40 PM
durielk's Avatar
Where do you ride that? No taillight & street tires?
Old 10-12-2011, 11:16 AM
Bazzy's Avatar
Decided against the white plastics and going back to black. Sanding them down and then spraying so they are extra gloss black.
I found some parts from an old project and decided to throw on a 2008 R6 taillight to the bike. Looks sick, brighter than the last one i was using. When I hit the brake, it lit up my entire garage. I'm not done with the bezel yet, it's just mounted right now. I need to go pick up some plastic sheets to finish it up.
I also got both side panels to the shape I want, now I just need to finish smoothing them out before paint. The process is long but once it's complete the panels will look factory
And here's a bonus shot of my headlight
Old 10-12-2011, 04:25 PM
+1 looks like some nice work. Not all hacked up. Some shots during process would be cool.
What's this, "i'll head back over to supermoto junkie" thin skin???
Dan
Old 10-12-2011, 07:30 PM
Bazzy's Avatar
Dan
Guess i'm used to more active boards haha.
No process shots, I always forget. So I am finishing the rear fender right now, the light cover looks pretty good. I decided to use krylon gloss black after I sanded it all down.. I'm on the 3rd coat now and it just looks terrible. Not sure what went wrong after 5 coats I'm going to clear coat it, if it's still bad I might actually shoot myself
Old 10-13-2011, 02:25 AM
Matasickle's Avatar
I say keep the white... it looks ****!
Old 10-13-2011, 06:08 AM
Bazzy's Avatar
Paint didn't turn out very good. Luckily I only tried the back fender first. I switched to a new front fender as well, it fits perfectly with the lines
My other camera died, here's some low res ones until tomorrow when I get a chance to take some real ones. I only get 1 day off every week and I never get a chance to finish my project bike
Old 10-13-2011, 06:15 AM
Bazzy's Avatar
i want a diy about this. thats bad ***. thats like one of the few things i would do with this bike is shave some size off the back panels. also where the f did you get white fenders, this is so unfair.
Look up plastic welding. From the top, I cut where the panel goes outward, and removed that section and plastic welded the two flat panels together. Of course I trimmed them quite a bit as well
For the rear fender, I took an '08 R6 taillight, PW'd brackets to hold it in place. Then I took about 4 inches off a front fender and cut the right shape out of the middle. once I got it looking good, I PW'd the cover over all the nasty seams and welds/brackets. Sand, paint, BAM bright taillight that looks killer
My next project after I finish painting will be making the headlight bezel. I'm still kinda drawing out what i want. I'll be using the OEM top section at least
Cutting the left side of the subframe and welding a new support.
Considering taller seat foam.. we'll see
It's about time for a new rear tire as well so I am probably going with a 140/70-17.
Shorty levers, hand guards
Once I get bored I might work on the motor.. that always means something bad for the bike at hand. It's usually my blowing the motor up making it fast or just dropping in a bigger motor. I wish the DRZ could fit, too tall though
2k1w=no$
12-29-2009 01:27 AM
GETRAD
03-24-2009 07:40 PM
AWhetstone
Ninja 650R
10-28-2008 08:10 PM
klxrdr
03-22-2008 10:57 PM
TheHulk
08-22-2006 01:46 AM
Quick Reply: Reshaped My Side Panels
