Replacing headlamp - can I go 100/80 watt?
Old 08-10-2014 | 03:50 AM
FOGeologist's Avatar
Default Replacing headlamp - can I go 100/80 watt?
So the stocker headlamp is rated at 60/55 watt.
Can I replace with an 100/80 watt, or will I experience problems?
Old 08-10-2014 | 05:12 AM
I put a bulb with that spec in a 1982 Kawasaki GPZ750 back when. The heat during 80w running was noticeable and the heat when running 100w was intense. I didn't melt the socket, but I've heard of this happening. Also, sometimes the stock wiring and/or fusing won't be compatible at high beam, so check that out. I wasn't impressed with the high beam angle. When the low beam was set ideally, the high beam tended to point too high. The low beam was pretty darned good, however. I ended up using a single auxilary fog style lamp with a good beam design on a separate switch for really outback and black night driving. I moved that auxilary light to other motorcycles, as it worked really well.
Old 08-10-2014 | 04:28 PM
I was worried more about over-drawing my hyper-active stator, which (now that I think of it) is producing almost double the minimum of VAC from operation. My new $100 regulator rectifier is shunting most of it to heat. Maybe a high-volt lamp will increase visibility and take some of the load off the RR?
I'll give it a try. If I'm over-driving the wiring I'll switch back down.
Old 08-10-2014 | 11:45 PM
So I just went and got a Phillips kind of mid-grade bulb and called it "quits."
Maybe if I get a case of the squirrellies this winter I'll drop in a 100/80 watter or I'll throw in an HID conversion kit. They're practically giving the danged things away.
Old 08-12-2014 | 01:03 AM
azdeuce's Avatar
I'm running a Piaa 4K.. 110/100
No probs at all.. Have one in the Harley too
RayCour
11-05-2014 03:05 PM
Monster Addict
06-03-2013 01:08 AM
hobbs74
09-01-2008 02:23 PM
pie4foou
02-01-2008 12:53 AM
2k1w=no$
04-28-2007 02:52 AM
Quick Reply: Replacing headlamp - can I go 100/80 watt?
