Repairing plastics, welding plastics
Old 02-13-2009 | 08:20 PM
"FYI... when you buy OEM plastics they come w/ the decals. My experience anyway..."
Ahh I see. They must sell the decals separately from the shroud for people that only need to replace the decal. Good to know
Heat gun might work to shine the plastic mandark, but I tried by using the welder, and only got OK results.
Old 02-13-2009 | 09:14 PM
eas's Avatar
eas
Default Plastic Welding Kit
RockyMountainATV/MC sells a plastic welder plus rods for $45.99 #103-596. I'm not sure if it's the same tool that Harbor Freight sells. If you do a search for kayak repair you'll find similar outfits. Kayaks use the same kind of plastic as dirt bikes and ATVs. Your job looks pretty good; much better than the zip tie stitching. Cover it with stickers and it'll look factory. An added benefit: you can fix your buddies' plastic, charge them a minimal fee, and the tool ends up paying for itself.
Old 02-16-2009 | 10:32 AM
wedge's Avatar
I just Frankenstein stitch it with tie wraps.... gives a little character to the bike.
hardly anyone notices anyway.
Its green; thats all that counts right?
Old 11-07-2009 | 01:41 AM
Follow up. Save your $$, don't bother with the plastic welder. When I was getting ready for the Bucky DS ride, (https://www.kawasakiforums.com/forum...t=30711&page=2) I decided to put the old shrouds on since I would be beating the bike a bit. Glad I put them on. I smashed the one that I had repaired earlier in this thread. I didn't expect the repaired shroud to be as good as new so I wasn't surprised when it didn't take much abuse before breaking again. I was just glad I put the beaters on.
Once back home I decided to give the shroud another weld job. I was getting OK results again, and then halfway through the repair the welder cooled off. I think it may have burned out some of the heating elements. After that I got an old wood burning iron (very similar to a soldering iron, which I'm sure would also work) out and used that to melt both sides back together. I actually think I got a deeper, better bond using the woodburner. It didn't give a very good finish but neither had the plastic welder. They both only made servicable repairs.
Dan
My 4 piece shroud
Old 11-07-2009 | 02:55 AM
RimBender's Avatar
Another method you can try that works with some kinds of plastic (like my snowmobile hood):
Glue the crack back together with superglue. When it dries, put more superglue in the v of the crack. Before it dries sprinkle baking soda on it. A chemical reaction will occur making hard surface that can almost be sanded. You can repeat f you want to build the area up. Best done on the back side where it can't be seen. Don't breathe the fumes.
Old 11-07-2009 | 03:15 AM
95451's Avatar
Great Job Dan!
Thats Pretty Cool Too
Old 11-07-2009 | 03:50 AM
neilaction's Avatar
My method was not as sophisticated but has held up.
Old 11-07-2009 | 04:59 AM
That looks good Neil, I almost went that route this time. Too bad these damn things cost so much.
Rimbender thanks for the tip, will keep it in mind.
Dan
Old 11-07-2009 | 09:15 AM
JasonFMX's Avatar
I have a few comments and suggestions:
1. I'm f#cking impressed............seriously. That doesn't happen often.
2. Doesn't matter if you used it once or not. It costs $30 for the welder, and ten bazillion for the new plastic and stickers,.....which you would have busted the next ride anyway!
3. You'll get better at the welding. That was your first bead, welding takes many hours of training my young Padawan.
4. After your second job, turn the panel around and get one of those little butane torches and just liiiiiiiiiightly melt the back till you get a penetrating fusion going on. Might help... I've been down this road a few times myself.
5. Yes, the heat gun will work to smooth. But, in my experience, it only works if your plastic is effed up really bad and you want improvement. In my experience, it won't make it new again. It also takes a trained hand. If you have any old plastic, buff it up and try your hand there first. Be careful though, the point you need to smooth the plastic is its melting point (obviously) and the rest of the plastic is near its collapsing point. If you do it right it will look good, not new, but good.
6. You can get plastic bonding stuff.... it has all sorts of names. It basically melts the plastic on a chemical level and bonds that way. Usually its a different color, but after some buffing and sanding...then get some stickers to cover it up. universal number backgrounds work well. Get green and cover it right up. Never know it was there.
Old 11-07-2009 | 03:17 PM
RimBender's Avatar
Best results with a plastic welder or any melt job (like a soldering iron) will be using the same plastic that your trying to mend. If you have an old cover or can find a place that you can trim off some plsstic, like a out of site reinforcing rib, shave it up into shreds with a pocket knife or something. Use that material for your weld fill. Most plastics today are complex combination of chemicals, so it is unlikely to find a filler the same unless you use the same stuff. Even then it's hard to get a good bond.
Auto body shops use glue like products to repair plastic bumpers that work pretty good, but not cheap.
Quick Reply: Repairing plastics, welding plastics
