Removing handlebar plugs
Old 10-18-2011, 09:41 PM
Ckahleer's Avatar
Default Removing handlebar plugs
I am trying to install a set of handguards, but there are steel plugs welded into the handle bar ends.
Any suggestions on how to get those plugs out?
Craig
Old 10-18-2011, 10:01 PM
cmott426's Avatar
leave them in and tap them. Then use that for the "Nut". Much better grip then the expandable nut that comes with the guards.
Old 10-19-2011, 12:31 AM
DYNOBOB's Avatar
I second that. Drill/tap is much, much easier.
Old 10-19-2011, 01:55 AM
Kenny M.'s Avatar
I thought I would grind the welds off and remove. Tried drilling first. Wow. went very quickly. About a minute and a half per side. Took about ten minutes per side to tap.
Old 10-19-2011, 12:19 PM
DYNOBOB's Avatar
What diameter drill bit did you use to drill out the weight?
Old 10-19-2011, 02:33 PM
Kenny M.'s Avatar
Drill size was 17/64. Tap size is 5/16-18
Old 10-19-2011, 09:23 PM
rgoers's Avatar
I used a Dremel with a carbide tip to take out the spot-welds. 5 Minutes each side, and I was done!
Old 10-20-2011, 12:58 AM
DYNOBOB's Avatar
My bad, I thought you were saying you drilled the entire weight out... The side I drilled the weight out took about a 5/8 drill bit and the bar got so hot it melted the grip glue.
Old 10-25-2011, 01:47 AM
mikesova's Avatar
I happened to have the correct tap for the bolts that come with the tusk guards that I received today (8MM x 1.25). I drilled the hole out and started tapping. I was taking my time and I broke the tap off in the plug...GRRR.
So now, I'm probably going to go buy some dremel stuff to grind the welds off. I'm kind of bummed, I was liking the idea of keeping the weights in there because the bars aren't vibratey now as it is and I'm scared that it will get bad...
Old 10-25-2011, 05:40 AM
LikesToThump's Avatar
tap extractor? round 2?
Quick Reply: Removing handlebar plugs
