Rejet comments from Dyno Jet
I'm running a 130 Mikuni & 32.5 pilot, BB 34 Mikuni, stock everything. I think where you run your screw determines your pilot, after you get it backed out near all the way, you need bigger; if you barely crack it you need smaller.
No mention of other jetting though.
Still trying to get my head around the best combination here in Calgary and surrounding mountains.
I see "rgoers" is as close as I seem to get to Calgary altitude.
Howard.
The KLX can still run quite well with an overly rich jetting setup, but I think that's why we hear some of the mileage complaints as a result.
A parts man who doesn't know how to look around in other CVK carbed bikes to find an optional size for your KLX. That said, while quite a few have installed bigger pilot jets than the OEM 35 size, most even with big bore kits seem to find that the 35 is more than sufficient. Among the biggest carb tuning impacts for the OEM CVK carb are replacing the lousy OEM needle and drilling out the starter jet. After that, matching the needle position and main jet to the given bike's modifications are also obviously quite important.
The #38 let the bike start so easy (no need for choke most the time) but it sure was rich and the rear fender black.
