rejet, bike starves for fuel
Old 06-30-2011, 04:14 PM
mel brooks's Avatar
My thought was venting too.
They might have pinched or kinked a vent line under the tank. If the cap doesn't do the trick, maybe pull the tank off and make sure the vent lines are not being constricted.
Old 06-30-2011, 04:18 PM
TNC is offline
Originally Posted by old man
Thanks, Did they have to pull the tank to work on the carb?
Yes, they did...unless they had a couple of very small people from the movie "Fantastic Journey" doing the work. And that's not sarcasm...it's a joke.
But seriously, the shop guy(s) did something in there even if it was just disturbing some sediment in the tank or float bowl that has now interrupted fuel flow.
Old 06-30-2011, 06:02 PM
old man's Avatar
They found it pretty quick, they did pinch the fuel line!
Bikes runs fine, not a big power pick up but very happy with the way it starts and how quiet it is when letting off the throttle.
Old 07-07-2011, 02:02 AM
Hey old man, Long time no talk, quick question, Do you know what jets they used and where about they positioned the clip, and also the a/f screw? just curious.
My **** runs like a screamin eagle but pops and backfires on decel. gets kinda old and kinda worried about it as well
Old 07-07-2011, 10:57 AM
Blackheart58's Avatar
Originally Posted by JRock420
...pops and backfires on decel. gets kinda old and kinda worried about it as well
Until he gets back to you, you can try to unscrew the A/F screw a bit more...it might help mitigate some of the deceleration popping. Of course, it could also be an air leak in from your exhaust gasket...
Old 07-07-2011, 12:06 PM
Thanks, I have it all apart, after work ill tinker with it...
Old 07-07-2011, 11:21 PM
Caution about turning it TOO far out...it can fall out when you're riding. I wouldn't go much past about 3.5 turns out. It doesn't do anything more to richen the mixture after that far out anyway...
mikesova
06-06-2012 01:09 AM
ewommack
08-29-2011 10:13 PM
scotty7676
10-19-2009 05:33 PM
06-18-2006 05:58 AM
Quick Reply: rejet, bike starves for fuel
