Rear tool bag removal
Old 10-15-2012, 02:39 AM
Rosed's Avatar
Default Rear tool bag removal
Has anyone removed the tool bag from the rear fender? If so what did you use to plug the holes?
Old 10-15-2012, 02:51 AM
BillMoore's Avatar
My nomadic rack covers them up quite nicely since it actually uses them as mounting locations.
Old 10-15-2012, 03:15 AM
Brieninsac's Avatar
Same here, my Pro Moto rack uses the same holes. I then have my tool kit mounted underneath.
Old 10-15-2012, 03:39 PM
bcliff's Avatar
I plugged to stock tool bag holes with fasteners to attach a dirt-bike-gear.com tool bag. I then plugged the holes to attach the Wolfman Enduro tool bag.
Old 10-15-2012, 04:03 PM
rgoers's Avatar
The Nomadic rack uses 2 of the 4 holes as mounting holes. I used the old hardware (nut/bolt/washer) to cover the remaining 2 holes.
If I knew I was never going to use the holes again, I would have plugged them with a couple of the giant-flange SS pop-rivits I have.
Old 10-15-2012, 05:07 PM
Rosed's Avatar
Thanks guys, I don't plan on installing a rack, I used the original hardware for the small holes, but will have to improvise on the 2 large holes.
Old 10-15-2012, 07:41 PM
drm's Avatar
drm
drm is offline
Old 10-15-2012, 07:45 PM
drm's Avatar
drm
drm is offline
Bcliff, do you use both the dirt bike gear and Wolfman bags?
Old 10-16-2012, 12:14 PM
bcliff's Avatar
I upgraded from the stock bag to the dirt-bike-gear bag to gain some additional room and recently have upgraded to the Wolfman for the same reason.
Old 10-16-2012, 02:39 PM
drm's Avatar
drm
drm is offline
Cool. Thanks.
I bought the largest dirt bike gear bag. How does the wolfman compare to the dirt bike gear bag?
Quick Reply: Rear tool bag removal
