Rear Sprocket
Mine "would" pull redline in 6th gear with my 13/47 and current engine setup, but I don't ever do it. Mine is an '06 "S" model with knobby tires, so I don't need to do whatever max speed is. I can see why an SF owner might want or need to. I cruise at a true 55 at about 7000 rpm as calibrated in a Trailtech Vapor instrument panel. I run a 110/100/18 rear tire. The bike is definitely not set up for interstate travel.
I wondered if it would be too low, but in Colorado in some off road conditions, the 14/47 was a hair too high. And not oddly, the 13/47 is pretty much like the KLX300 model's 14/50 stock gearing.
I currently have the stock 14/42, but 6th just won't wind out (FMF pipe, k&n filter, 125 main jet ???...according to the previous owner).
Thoughts on going to 13/42? Gearing down for the woods couldn't hurt, but wasn't sure how it would effect the top end on the highway.
9k in 6th gear? Doesn't a rev limiter kick in before then?
My 06 begins missing around 8k. I haven't been able to pin point exactly where it begins missing...and maybe its jetting??? Previous owner thinks he put in 125 main jet. Could a slightly larger main jet help high rev miss?
Speaking only from my personal experience and not as a professional mechanic although I do play one on TV.... (OK I lied about that part) an engine missing at high rpm whether car or (4 stroke) bike engine is an ignition problem. As I say this has been my experience but I could believe it is getting starved of gas at high rpms due to jetting but it's just not something I have seen. Easy to put a new plug in it to see if that makes any difference. Plug wire shorting? I have a habit of being quick to blame electrical problems.
