rear sprocket
you might need a new longer chain probably...pretty simple...rear wheel..27mm left bolt...right bolt..use needle nose pliers to bend the pin straight and pull out....22mm to loosen the right bolt....12mm open wrench to loose the small fine adjustment bolt away from the wheel bolt first...loosen that all the way to the head of the bolt....do the same on the other side...take chain off the rear sprocket...wheel comes off...
LordVngr
09-24-2006 06:03 AM
