rear sprocket
Old 02-16-2012, 01:37 PM
cegusman's Avatar
Default rear sprocket
What other bike rear sprockets fit the 09 250s. When looking online no one lists the KLX in there lists.
*Edit* Found some that will work but no 39 tooth. Any recommendations?
Old 02-16-2012, 02:45 PM
Green250SF's Avatar
Try Vortex sprockets. They make a 39 tooth rear sprocket specifically for KLX's. I believe they are aluminum so they won't last as long as the stocker.
Old 02-16-2012, 02:57 PM
cegusman's Avatar
Thanks.
Got a stock one on ebay with only 766 miles on it. $9.99 cant beat that.
Old 02-16-2012, 03:04 PM
Old 02-16-2012, 06:45 PM
ahnh666's Avatar
can 16t fit a klx?...looked like the 15t was a tight fit...i couldn't even put back the case saver....
Originally Posted by EMS_0525
Old 02-16-2012, 07:02 PM
RobG's Avatar
If I went to a 45T in back (with a 14T up front), what length chain would I need? And if I went with, say, a 47 or 48T in back, would it need to be longer still? AND, could I run the longer chain with the 45 so I could swap between the two?
Rob
Old 02-16-2012, 07:44 PM
Rob
I ran a 49T in rear with 13,14,15 up front and 110 link chain.
Now at 45T rear with 13,14,15 up front and 108 link chain. At least that's what I think. Isn't stock 106?
I bought the longer chain and cut it to length.
Old 02-16-2012, 07:50 PM
I run a 15T up front with the case saver in place. It's close between the chain and saver, but there is a gap and I never have observed any wear from contact between chain and saver. As close as the 15 is, I don't see how a 16T would fit with the saver.
Old 02-16-2012, 10:57 PM
ahnh666's Avatar
the case saver looked like it was almost touching the chain....i didn't even attempt to ride with the case saver on...i'll try tonight...
Old 03-23-2012, 09:34 PM
Babaloo's Avatar
I just added at 13T and couldn't tell a difference so Im thinking of adding a 45T or 48T to the rear. Is there a post which explains removal of the rear...
Quick Reply: rear sprocket
