Rear Spring Upgrade
#31
It is not the spring that rubs against the intake, but the spring seat adjusters. They are a larger diameter than the spring. So the larger spring diameter isn't a problem.
I got the stock spring rate (5.6) off the Race Tech website. The 6.2 I installed is stiffer.
#32
Yes it can be the length of the new spring, when the sag is set properly the adjuster and whatever washer or seat you use can be in a place where it can rub. It can seem like it clears but after a few rides you can see it. .49 , 6.4 F R, I'm 190.
