Rear Brake not engaging
There is no adjustment on brakes. You might have gotten an air bubble in the system. You can try to bleed the rear brake and this should take care of the problem. If not you may have to rebuild the master cylinder.
Just had this happen on a friends sport bike and a simple bleed did the trick.
I modified my bleeder with a old Mt. Dew bottle (seem to be plenty of those around here) I drilled a hole in the cap the same size as the tubing, slid the tube through the cap and wrapped it with electrical tape. Works great, truly makes bleeding brakes a one man job, and you don't lose any fluid.
http://www.rockymountainatvmc.com/do...%20Bleeder.pdf
My '09 has an adjuster for brake pedal position, which in turn provides more leverage (pressure) at the master cylinder. If adjustments don't help -
I'd lift the rear, and look it over carefully. Are the pistons coming out when you depress the brake pedal? Is there oil on the rotor (as someone else suggested)? Pads worn? Pads correct pads? Look it over carefully...
kronus
06-27-2008 01:27 AM
funtoos
03-28-2006 09:04 PM
