re jet help for lazy old man
Old 01-22-2010, 11:15 PM
barbz's Avatar
09 has a different needle to the 300 and 06/07 kit. The 09 kit also gives you a new spring instead of asking you to drill out the slide hole.
I believe the 300 kit still brings the best performance on all models.
Paul
________
Lovely Wendie99
Old 02-08-2010, 04:26 PM
NorthRider's Avatar
I've been trying to figure this out as well.... as i also have a 2007 KLX250 which is not specifically listed on the the Dynojet website.
On the DJ website it appears that there are three kits listed for the KLX250/300 ... 2152, 2182, and the 2206.
Both the 2152 and 2182 kits have the same parts listed and include the spring, but do not include the drillbit for the slide, nor is drilling the slide mentioned in their pdf installation instructions... i did note that they both provide the same part number on the needle.
The 2206 kit for the klx300 does not include the spring although it does include slide drilling instructions/drillbit, although the part number on the needle is different.
So i guess my follow up question would be...
1, what's the difference in the needles between the 2006-klx300 and the 2009-10 klx250s/sf...??
2. why doesnt the "new" kits instruct to drill the slide
3. does it really need a new spring..?
I was thinking that they may have designed a better needle for the 2009/2010 models and that they figure everyone already knows how to drill the slide and dont want to bother supplying the drillbit or complicating the instructions..?? just wondering why they didn't include my 2007 model for this kit.
I guess i was thinking of going with the 2152 kit since it included the spring and provided a few more jets although i am concerned that i might be missing out on the performance of the klx300 needle.
anyone got any thoughts on that one..??
Old 02-09-2010, 01:12 AM
WestOzKLX's Avatar
Originally Posted by KLXer
I went with the 300 kit. Might try looking at the instructions to see what parts are different (if any) or what initial specs are different. Many people here have the 300 kit in their 06/07 250s.
300 kit is the one. The needle taper is 'more agressive' and suits the 250 just fine. The new 09 kit has a 'softer' needle and comes with a softer spring for the carb', otherwise they are the same.
Old 02-09-2010, 01:20 AM
WestOzKLX's Avatar
Originally Posted by northrider
i've been trying to figure this out as well.... As i also have a 2007 klx250 which is not specifically listed on the the dynojet website.
On the dj website it appears that there are three kits listed for the klx250/300 ... 2152, 2182, and the 2206.
Both the 2152 and 2182 kits have the same parts listed and include the spring, but do not include the drillbit for the slide, nor is drilling the slide mentioned in their pdf installation instructions... I did note that they both provide the same part number on the needle.
1, what's the difference in the needles between the 2006-klx300 and the 2009-10 klx250s/sf...??see my post above.:d
2. Why doesnt the "new" kits instruct to drill the slidebecause the softer spring will do the same job, allow the slide to rise by being overpowered by the vacuum.
3. Does it really need a new spring..?no. Drilling the vacuum hole does the job just fine.
i was thinking that they may have designed a better needle for the 2009/2010 models wrong and that they figure everyone already knows how to drill the slide and dont want to bother supplying the drillbit or complicating the instructions..?? Just wondering why they didn't include my 2007 model for this kit.the 09 was aimed at a 'softer ' market, hence the lower suspension etc. So they've designed a 'softer' kit.
i guess i was thinking of going with the 2152 kit since it included the spring and provided a few more jets although i am concerned that i might be missing out on the performance of the klx300 needle.don't do it. #2206, your bike will thank you.
:d:d:d
Old 02-09-2010, 12:50 PM
roadglider's Avatar
NorthRider the idea behind the softer spring or drilling the slide is to improve the throttle response by allowing the slide to lift faster. You can do this by either using a softer spring or increasing the diameter of the vacuum port in the slide. You do one or the other, thats why if the kit includeds a softer spring there are no directions for drilling and no drill bit.
Old 02-09-2010, 03:33 PM
Ranger Ron's Avatar
The new 09 kit has a 'softer' needle...
I guess I have a language barrier problem. We do talk funny up here, you know.
What do you mean by "softer?
In the picture the 300 needle looks to have a double taper and appears substantially richer.
Ron
Old 02-09-2010, 07:42 PM
barbz's Avatar
I believe it's not as aggressive as the 09 needle.
Go the 300 kit
Paul
________
Buick Ln3 3.8L Mpfi- How It Works
Old 02-10-2010, 03:52 PM
Ranger Ron's Avatar
I still don't get it.
Needles are passive. They vary the mid range mixture (richer/leaner) by their shape. What's the connotation of aggressive or non-aggressive?
Ron
Old 02-10-2010, 04:10 PM
ol'klx-er's Avatar
The needle in the 2009 kit has a very smooth taper (non-aggressive), the older needle has no taper initially then almost a step where the taper starts (aggressive); the taper is a bit more pronounced as it is shorter.
tommy48
05-07-2010 01:01 AM
zzrick
12-05-2008 04:02 PM
Worlok14
07-12-2008 05:52 AM
firstninjabike
06-23-2008 10:22 PM
evil636
02-02-2006 10:02 AM
Quick Reply: re jet help for lazy old man
