Ran into some difficulty
well I went to replace my bent clutch lever the other day and realized I have no idea how to take the tension off the cable,anybody know how?
Thanks,
Hunter.
Thanks,
Hunter.
All you do is line up the grooves on the adjuster to the perch. Then pull in the clutch, grab the cable and pull forward away from perch,then quickly release clutch lever. It will pop right out of the adjuster. To put back on put cable end in lever first, stretch cable over the big adjuster nut,hold in place,pull in lever,then release quickly. it pops back in.
marc
marc
chubaka
06-23-2006 01:15 AM
