Quietest pipe for 2009 KLX 250?
The Q4 has crappy packing in it. If you get the repacking kit from FMF it sounds really nice. @4,000 rpms it makes 90db on a 250 with a stock header. I know this because I got a sound check at the Wabeno ride last September.
I drive too much like an idiot to make noise and draw attention to my self. I much prefer the quiet. I will even give up some performance for the quiet. I think I found a nice middle road.
Going to try a 1" pipe instead of 3/4. Right now I have rigid copper pipe for an extension. It looks pretty good and sounds nearly as quiet as stock.
You folks say these are reasonable except when really getting on it. I do that all the time. I have the 351 kit and going for the Mikuni 36-68
David
David
You can also really change the sound of any pipe with some creative packing for more or less sound and as it burns and blows out it will get louder. My Powercore 4 is allready louder than when I installed it, it has slightly less than 1000 miles on it.
Lets see if I got this right. Less muffler, more power? So a straight pipe or even no pipe would give more power? What is the purpose of that little bulb in some aftermarket header pipes? Is it maybe cosmetic to make us think their engineers really care about us klx owners?
Also as a noob, how do I private message a particular response. I've clicked all the buttons but still don't get it.
The aftermarket pipes (slip on mufflers) are mostly hollow with the packing on the outside to absorb the noise. It does work to a point. Sound waves and exhaust gasses are different but come out of the same place at the same time. A good muffler will take out the noise and let the gasses leave easily with little resistance (back pressure) My BMW 1100 twin is quiet. No after market muffler will get me more than 5 more horse power with all the noise you can stand. Its a well designed muffler made for that bike.
For private message click on the name there will be a menu.
David
I want a quiet aftermarket too. They don't make one. There is a clip on here some where that shows the FMF Q4 as the quietest, but its still too loud for me.
I changed the stock pipe. I removed the 15 mm outlet and installed a 22 mm outlet (3/4" pipe) I can tell the difference in power but its still quiet. I even went to the police station and asked a cop.
"Is this too loud?" "No not at all".
Just a little bit louder than stock. Not near as loud as no air cleaner cover.
If you want, I can do yours.
I plan to dyno test it this winter. I bought a stock pipe to compare it to.
David
David
David I like the ingenuity. I always appreciate someone who tries to come up with their own solution. Everybody has their own idea of what they need from their muffler. Keep up the good work.
Feral Donkey, how did you like Wabeno? People at the Bucky, and at the ride in Theilman MN kept telling me Wabeno was not to be missed. Did you do both days? Was there any difficulty to it? I just may do it next year.
Thanks
Dan
I'm very happy with the sound of my Q4,. The original packing lasted 2 yrs, and was probably still ok. I swapped it out with some inexpensive packing from Rocky Mt ATV LEXX brand. I put a thread up about it if you want to search. It blew about 91db at 3500 rpms at the Bucky ride in Madison.
Thanks
Dan
Thanks
Dan
