Putting the KLX on a diet
Even with bicycles they are not as robust. They tend to round off easier as well.
Rinaldi RMX35 Extreme 100/100-18 and 80/100-21
Handlebar 22mm Renthal
Ballistic Battery
FMF PowerCore+PowerBomb to reduce significantly the noise
Remove the system front and rear lighting and replace with a lighter
Como quitarle peso a la Klx 250 - Kawasaki - 2y4t.com
Ballistic Battery
li-ion battery -5 pounds.
exhaust - lots of pounds
renthal sprocket -1ish pounds
renthal handlebars.
remove smog stuff
are there aftermarket radiators?
plastic gas tank
smaller rims?
lowering (for lower gravity)
alloy footpegs
radical: remove airbox and retrofit a kn filter?
digital (small) speedo
not sure about chain, but I am sure there is something out there lighter than stock.
renthal handlebars.
remove smog stuff
plastic gas tank
smaller rims?
alloy footpegs
Dan
I thought changing from the "heavy" oem exhaust to the FMF Q4 would save weight but upon picking both up at the same time, there is no significant difference. Still worth doing for the nice sound and performance but don't do it for weight.
You don't believe it, put them on a scale. OEM isn't heavy.
