Project - Full Exhaust / DJ kit/smog removal complete
Finished up install of FMF Powercore 4 muffler (removed SA)/ Powerbomb head pipe, DJ kit, remove air cleaner lid and smog removal. All i can say is OMG what a difference. It has woke up and feels damm near like a KX. Started first try, shut off choke after couple minutes and ran beautiful (never did this prior). Very responsive. Would recommend this combo to anyone....
2006 KLX 250S
2006 KLX 250S
Kawasaki KLX 250 slip on - HMF Engineering Forums
https://www.kawasakiforums.com/forum...ompleted-8886/
Guys- I appreciate the help. I have the dyno jet info and I am being told on even the 2010 model you drill out the choke flow hole. Its not in the directions. Also looking at the best header and exhaust combo...ne input. Thanks
Keep searching the forum and you'll find lots of opinions on the header/exhaust combo.
Correct, the dynojet kit does not include choke adjustments. You need to do this yourself. Hardest part is finding that tiny drill bit(0.018", #77, 0.4572mm) and being very careful to not break it off. It made a huge difference on my 2009.
I drove mine to work the other day, it was about 34°, I pulled the choke and hit the starter, it fired and ran at about 2500 and within 10 seconds was getting close to 4000 RPM's so I pushed the chock off.
Odd how one of the 09 carbs (like mine) chokes perfectly and another is totally screwed up. Mine is not drilled, I have the Dynojet kit stage 2 in and nothing else, starting is the last of my worries.
Thanks guys. Im picking up my 2010 this weekend. I am going to break it in a little bit then do the airbox, stage 2, header, exhaust, and sprocket. I gotta obtain the parts slow, wifes pissed I dont dry my vrod now i am getting this toy.
