Problems starting bike when hot.
![Smile](https://www.kawasakiforums.com/forum/images/smilies/smile.gif)
I came to the conclusion that for less than $10 I wouldn't chance it. I would buy a new one.
$$Dan$$
They grind like D2 or something similar. They're at least 60RC. My scribe wouldn't even leave a line in them before and after grinding. .0003" passes and I blocked them in with strips of banding material. I only took off a thou/side or so.
You just took me back about 4 years
Before I was at the shop I'm at, I worked in a header shop for 17 yrs. We made replaceable caps for our dies out of D2, or S7, they were about 62 rockwell, and we ground them on the table the same way. The fastener industry is loosing a lot of business to china, we did a lot of work for automotive suppliers too. Between china and the crappy economy that little die shop was slowly going under. Good luck with the shims, I really don't think .001 off a side is going to ruin them even if they are case hard.
Dan
Dan
I ended up with both exhaust valves with .009" clearance cold. A lot of the problem went away. Then I played with the jetting and pilot screw a little more and almost got it all gone. I still need to gas it some when starting it hot. The smog pump went out in the trash and the hoses are plugged off. I don't know if that did anything or just made me feel good about myself. ![Stick Out Tongue](https://www.kawasakiforums.com/forum/images/smilies/tongue.gif)
Can I just slice a chunk off this spark plug wire and screw the boot back in again? When removing the smog pump thing it came off the barbed sheetmetal things on the frame suddenly and violently. It took the spark plug wire with it. Pulled it right out of the end with the spark plug boot. I looked at it and screwed it back in again. Then I checked it for spark and it was a little yellowish but the battery seems to be losing juice fast too. I think maybe that's the next place to look.
The more I tinker with this bike, the more I realize I really like this little bike.
