Problem Drilling Airbox?
Well I started doing the mods today. Had no problem with carb mod, or drilling exhaust, but I hate to ask a dumb question and sound like the village idiot,but how do you drill the airbox? I can't get a drill close enough because there is aroundcross frame pieceright in the way. I tried to take off the airbox but gave up on that. Do you need a special tool? HELP!
RE: Problem Drilling Airbox?
I did it by reaching the drill bit up in there and turning it by hand as far as possible. Then used a pair of needle nose vise grips to finish the job. The bit will want to just thread on there so you will need to work it a little to be able to spin the bit freely. Be sure and vacuum and/or blow out all the shavings. Sounds like a pain, but not that bad and can be done in about 15 minutes.
Thanks, I thought I was losing my mind. It sounded so easy I didn't even question the "how to" part when I read the mods. I'll get back on it first thing tomorrow. Can't wait to see how it runs.
ORIGINAL: 2k1w=no$
Some guys are just heating the drill bit up and pushing the bit through. It also saves from having to clean up on shavings.
https://www.kawasakiforums.com/m_17800/mpage_4/tm.htm
