Please help electrics
I have a klx 250, after going for a long ride 5 minutes in return bike wouldn’t start. I have a new battery which I have also replaced so I’m now on second New battery. I can run start and runs fine, light blinkers ect all work so the battery not draining. I only have electric start when press button I can hear the starter clicking over. Was going to take it to mechanic but thought I’d check here first Incase it’s something easy to fix cheers
You'll need a voltmeter to diagnose this. Normal battery voltage w/engine off is usually above 12.5V When the engine is running is should be above 14V. The shop manual pdf file has the steps to find out what's wrong-look at it.
