pictures
pictures
I ran across a post explaining how to post full size pictures and multiple pictures but I can't find it again. Can anyone point me in the right direction? I tried search but must not be using the correct term.
RE: pictures
In the screen shot below, I put a square about the 'insert image' button. The is what you will use to insert multiple and/or full sized images. You will have to have a place on the web to store your images first though. I use photobucket. Once you have uploaded your photosto the web, you can click on the 'insert image' button, then paste/enter the URL foreach photo.
RE: pictures
Once you open the reply box;
Option 1- click this box and copy in theURL from where you have saved yourpicture file online. I use www.photobucket for this.
once you enter the URL and clickOK the picture will appear below your text. This option creates the largest picture and use the least amount of bandwidth. Better for the site.
Option # II - Put a check in the box that says"Embed picture in post" and then click to the left of that where it says "Click here to upload!" then locate where the picture fileis stored on your computer and double click it. It will then be uploaded on to the site. It will tell you if your picture was uploaded successfully or if it is to large, if its to large you need to resize it.
Let me know if you need more help.
