perfect setup and dyno run
Old 08-23-2008, 11:17 AM
barthel75's Avatar
Default perfect setup and dyno run
alright here you go i live in pa dyno my bike yesterday playing with it for 2 hours here is what i got 27.13 horsepower with perfect air fuel and nice even curve with this setup
clip on second notch with 2 spacers on top and one under
fuel screw at 3 turns
main jet 128
pilot jet 38
snorkel in
2 brothers pipe
Old 08-23-2008, 11:27 AM
neilaction's Avatar
Well done.
Very good number.
I only got 26 with a 300 kit, pumper, BG full system.
Old 08-23-2008, 11:34 AM
jsac's Avatar
27 ponies with stock jug? more details pls........
Old 08-23-2008, 11:40 AM
barthel75's Avatar
what more do you want to know leave me know
Old 08-23-2008, 01:01 PM
tremor38's Avatar
main jet 128
pilot jet 38
snorkel in
2 brothers pipe
I have a few questions for curiousity sake
1. What did you use for the rear tire?
2. What was the air temp?
3. What altitude where you at?
Old 08-23-2008, 01:46 PM
redpillar's Avatar
Also, what bike?
Old 08-23-2008, 01:50 PM
barthel75's Avatar
09 klx250s rear tire avon roadrider air temp not sure our dyno room is fai weather not to hot i live in pa
Old 08-23-2008, 02:02 PM
redpillar's Avatar
Stock header pipe?
Old 08-23-2008, 02:34 PM
tremor38's Avatar
yeah the smoother the rear tire is, the better it hooks-up with the dyno's drum. I did a dyno run with my D-tracker in the winter time, when it was still 250cc, with a perfectly jetted pumper carb, aftermarket pipe and enlarged airbox hole. It peaked at 28hp. Finding that number hard to accept, I went to a different dyno and it peaked at nearly 30!
I know there can be different results between different dyno's, but I also think that there is enough variation in the kawi's parts manufacturing that you get some pretty wide variations in engine HP. That's the only thing I can think of when I try to answer why I've personally seen two similarly setup KLX's have like a 3-4hp split on the same dyno.
Old 08-23-2008, 06:28 PM
punkenduro09's Avatar
is the 27 corrected or uncorrected. this may explain something.
Quick Reply: perfect setup and dyno run
