Oxygen sensor and jetting
Old 07-15-2006 | 06:11 AM
57piper's Avatar
Default Oxygen sensor and jetting
Has anyone tried using an oxygen sensor to get their jetting correct? Its just a thought that I had. single wire oxygen sensors are pretty cheap and produce a approx. .5 volts at 14.7:1 AFR. less than .5 is lean and over .5 is rich. In theory a guy could install one in the head pipe and have it hooked up to a DMM mounted on the bars. could be a poor mans AFR-rich lean gauge. Just a thought.
Old 07-15-2006 | 01:46 PM
Default RE: Oxygen sensor and jetting
a couple of you mechanics can use a emissins test machine, the old ones, that sticks a sensor up the tailpipe, to see how its running... just a thaught cause now i know there is a few mechanics here, wish i had access to one of those machines....
thekeeper199
06-19-2015 03:19 PM
thomasy
09-21-2006 02:56 AM
rickyzx
06-01-2006 05:23 AM
Dragon
04-13-2006 08:10 AM
eztalking
09-14-2005 12:10 AM
Quick Reply: Oxygen sensor and jetting
