Ordered a sprocket and chain....
Old 07-09-2012, 10:43 PM
Originally Posted by redpillar
Did you say that the 45 will allow the same chain length?
It does on my '06. I'm 15/45 right now and the snail adjuster is on 3 or 3.5.
It would suck to run out of fuel out there!
Old 07-09-2012, 11:41 PM
redpillar's Avatar
Here is what the calculator says,
14/42 …3.00 15/45…..3.00
13/42….3.23 14/45 ….3.21
15/42….2.80 13/45…..3.46
Which means that the only real difference between the two is with the 13/45.
Interesting.
Yes the fun meter drops off when the fuel starts to slosh around the bottom of the wings.
Old 07-10-2012, 05:11 AM
Interesting.
RP: you been sipping tonight? 3.00 --> 3.23 --> 2.80 ...
Shouldn't that last one be 12/42?
Old 07-10-2012, 12:14 PM
durielk's Avatar
I would question whether a 12T would even work. It would be better not to go that small.
As for sprockets, run the 13, if you don't need the power, shift. I'm thinking the gas mileage would be the same regardless, it is the same amount of work & probably easier in the lower gear.
Old 07-10-2012, 12:34 PM
I'm not suggesting a 12T be used. It will work as earlier posters tried it IIRC. Besides chain wear, you risk wearing the front chain sliders faster. From my personal experience, higher gearing gives better fuel mileage. My worst mileage was with 13/49. But that may be more a factor of where and how we were riding than the gear ratio.
Old 07-10-2012, 10:14 PM
redpillar's Avatar
Nope a 15/42 give a final ratio of 2.80
Old 07-11-2012, 12:25 AM
Something is wrong with their calculator then. Cause it doesn't make any sense that a 15/42 is lower than either a 13/42 or 14/42. Check gearingcommander.com too.
My apologies for any accusation of imbibing. I know you don't do those things...
  #28
Old 07-11-2012, 02:02 AM
ol'klx-er's Avatar
It's one of those counterintuitive numbers. Think about wire gauge numbers: 18 is smaller wire than 14.
Gearing no one would run: 15/30 = 2.0
  #29
Old 07-11-2012, 02:28 AM
redpillar's Avatar
[QUOTE=IDRIDR;477791]Something is wrong with their calculator then. Cause it doesn't make any sense that a 15/42 is lower than either a 13/42 or 14/42. Check gearingcommander.com too.
I would never drink and post on purpose. but 2.80 is taller gearing than 3.23
I gotta go get a beer...
  #30
Old 07-11-2012, 03:02 AM
wildcard's Avatar
+1
the smaller the number the "higher" or "taller" the gearing.
Quick Reply: Ordered a sprocket and chain....
