Opps Dropped It... Clutch Switch Q?
Solder them together then send me the switch
maninthesea, I'm going to hang on to it for a while, and see if I'm idiot proof without it.
Dan
Ok, picked this up on another site. Poster claimed that "bridging" the switch opened up a second ignition map or setting. That the KLX250 EFI wouldn't rev much above 7500 rpms? My switch does not function, or permit me to start in gear by simply disengaging the clutch. So if I understand you are saying that this "bypass" negates a rpm limiter?
To those concerned about breaking the switch at the clutch lever while off-road, well that's why wrap-around handguards exist.
There's no good reason to ever be able to start a bike in gear with the clutch lever fully released, so not sure why it's popular here to bypass the switch and then continue to bend or break clutch levers. Fix the problem right at the source - don't band-aid it and sacrifice a senseable safety feature.
#28
Yep, in America there is a switch on the clutch, and I assumed it was there to enable starting in gear. Most every bike I have has these, but I read that post, where bypassing it would give you some performance benefits. It didn't indicate whether it was for bikes destined for what country. I will pursue whatever route that allows me to be able to start the bike in gear. I don't need a switch to tell me that I need to disengage my clutch first or a little green light on the dash to tell me it's in neutral, most of the bikes I've ridden in the last 52 yrs had neither
#29
Hi Everyone!!!
I got an update email... I forgot about this post. But I remember the incident.
I broke the little spring activated device in the clutch lever area.
Bottom line. I never did any repair or bypass nor did I buy the new $20 part.
But, the down side was it would "try" to start in gear if you didn't pull in the clutch.
I always pull in the clutch, So I didn't need a $20 part to help remind me.
After reading some bypass rev limiter stuff. I didn't remember any perks at all.
It was fun to think about my Kawi again. I switched to Team Husky.... lol
Ride safe!
Ride safe!
#30
