Oppening up the stock exhaust can and rejetting
Old 10-19-2007, 12:56 AM
zapitbullseye's Avatar
Default RE: Oppening up the stock exhaust can and rejetting
Ditch the lid completely, and do this:
https://www.kawasakiforums.com/m_192966/tm.htm
VERY pleased with the power now..........
Old 10-19-2007, 01:02 AM
2k1w=no$'s Avatar
Mudjunkie said it, if you haven't dropped your gearing a 13 tooth front sprocket is the best bang for the buck. If you do that and the "free" mods you will see an improvement.
sam83's Avatar
ORIGINAL: bryantjt
The sloppy welds are at the engine side of the headpipe. Remove the 2 nuts on the flange and pull off the headpipe and either file or grind them down ALMOST flush to the pipe diameter. As sloppy as they were I didn't trust that they had good penetration so I left maybe 1/16" of weld bead sticking up.
Opens up a flow restriction?
Old 10-19-2007, 03:07 PM
klx250s_rider's Avatar
Maybe we should start a "financial aid" post for the muffler and carb jet deprived KLX owners? Call it K.A.R.E. - Kawasaki Aid for Rejetting and Exhaust!
Old 10-19-2007, 08:03 PM
2k1w=no$'s Avatar
I donated $300 to that fund. It went to the ebay dealer to get myself a new exhaust.
Old 10-20-2007, 11:16 AM
mudjunkie's Avatar
zapitbullseye found something good...if your tight for cash or simply don't want to spend the dough for a slip on or full system, opening up the stock exhaust is pretty darn cheap and fairly easy to do..weld in a new end cap and presto it sounds good, runs pretty darn well, better than nothing..
Kobrakriss
08-04-2010 03:35 AM
dacoontz
01-28-2008 05:35 PM
Pmaill
10-24-2007 01:43 AM
bryantjt
06-17-2006 04:47 PM
05-24-2006 10:08 PM
Quick Reply: Oppening up the stock exhaust can and rejetting
