Opening up the KLX250S
Old 07-31-2008, 05:05 AM
rbarchi's Avatar
That was my rationale for getting the kit. I think, though the needle has a little different geometry than the N1TC. Probably not noticeable. Both are far better than the dumbed down one that is stock.
  #72
Old 10-31-2008, 04:23 AM
SlapDrum's Avatar
Default Exhaust and the other steps to power...
Did it change the sound when you drilled the 1/2" hole in the exhaust?
If yes, better or worse? lower the pitch or higher. Louder?
I want to do it but once there is a hole. Then there is a hole forever.
I was thinking about doing the list one at a time. Is there a suggested order I should follow. Are there any steps that Must be done together?
KLX250S owner, with 155 miles on the OD and lovin it!
Thanks!
  #73
Old 10-31-2008, 04:24 PM
jro's Avatar
jro
jro is offline
The half inch hole in the exhaust changes the tone a wee bit- a bit of a bark- but its still pretty quiet. Having no snorkel in the airbox is way louder than having the 1/2" hole.
  #74
Old 11-08-2008, 06:02 PM
cosmickites's Avatar
Default smog system removal
i am interested in doing this mod however i am not really sure what parts need to be removed and capped.
does anyone have a picture of what needs to be done?
thank you
  #75
Old 11-09-2008, 01:32 AM
WestOzKLX's Avatar
See here. KLX300R and KLX250S 09 DJ needle. Very different. This bike loves a lot of gas up top on WOT. The 300R needle reflects this, the 09 250S doesn't.
  #76
Old 03-19-2009, 07:09 PM
Default Drilled the crankcase vent hole
can you pleaes give me more info on this? i have removed teh snorkel from the airbox, is this the same thing in a sence? sorry about my ignoarance, just dont want to F someting up.
any pics would be apprecited or must a marked up diagram. thanks
2) Drilled the crankcase vent hole at the lower front right hand corner of the airbox out to 3/8". Like the KLX300, this system is plugged up and enlarging the hole helps move air out of the crankcase. It also means oil has a clear shot at your airbox if you lay the bike over.
  #77
Old 03-19-2009, 07:51 PM
mee2yoo's Avatar
I did not see where you said that you cut out the screen backing out of the air filter holder. This is important too. It seems like it wouldn't make much difference, but it does. Remember, More air + More fuel= More HP =-)
  #78
Old 05-04-2009, 02:35 AM
BCLS482's Avatar
Default Carb slide vent hole question
Earlier postings to this thread mention drilling out the carb slide vent to 7/64ths in order to increase throttle response in older bikes. Later postings do not mention this modification. Is this mod not effective, or has Keihin taken care of it on the 2009 model ?
BCLS482, in Cowichan Bay, BC, Canada
green '09, full Muzzy exhaust, Dynojet stage 2, air box lid removed, backfire screen removed, 13t front sprocket.
  #79
Old 07-29-2009, 02:36 AM
slippery750's Avatar
I have the SF and was wondering about this mod to the slide too...
  #80
Old 07-29-2009, 02:47 AM
WestOzKLX's Avatar
Take out the slide from the carb' (only requires you to remove the side panels and the tank and the carb' top,) and measure the vent hole. If a 7/64" bit wont slide through the vent, then drill it out so it will.
Quick Reply: Opening up the KLX250S
