Okay - A Quick Tutorial is in Order
On the suspension settings, both front and rear.
Compression dampening on front fork: higher number of 'clicks' out for lighter, less for heavier rider?
Compression dampening on rear shock: higher number of 'clicks' out for lighter, less for heavier rider?
Rebound dampening on rear shock: higher number of 'clicks' out for lighter, less for heavier rider?
I see that Todd has his set for '4' and others have them for a higher number.
On other bikes, these adjustments can make a huge difference.
Front forks - what is the oil level supposed to be set at? Might be another thing I do on the bike. Set the oil level a bit higher to stiffen up the front just a tad.
RE: Okay - A Quick Tutorial is in Order
ORIGINAL: Marty
I have heard that we have 5w fork oil in our forks, maybe going to 10w will help stiffen them up (Anybody please correct me if I am wrong). I also remember tony saying that he changed the oil in his forks and shock to hondaline fork oil and this supposidly helped his out quite a bit. But, I do not remember what wt he used.
I was adjusting the front/rear shocks on my predator a few weeks back, and it was all the way clockwise I believe was the stiffest and then bring it back counterclockwise as many number of clicks as needed. I am guessing it is the same way without looking in the klx manual.
So, if one set the compression dampening for a 4 and the rebound for a 12 they would have a suspension that was stiff to compress, but recovered quickly?
