Oil filter
#81
Dan
#83
Personally I like to use gorilla glue. It expands to fill all the voids to keep all the dirt out so the bearing stays clean.
#84
Ray, I'm glad you asked, I just changed my muffler bearings, and was wondering the same thing. ?????????? Dan
#85
when is zero not zero
Semi-synthetic kind of makes more sense than the partial zero emissions emblem on the back of my subaru...
#86
I'm sure that the MufflerKing had a favorite muffler bearing manufacturer. The one and only to use. No other would do. Anyone remember which manufacturer that was, because my muffler was just repacked and the shop dude said the bearing was shot and didn't know which one to order?
Thanks for all your help.
#87
I see an oil filter with a hole in each end. I do know the proper orientation in which it goes into my bike.
#88
A) Cannot put a filter on straight
B) Cannot put a drain plug in straight
C) Cannot get the terminology straight
Next time you shop for oils, notice the types that have partial synthetic and partial conventional are labeled as synthetic blend
Last edited by whyzee; 02-02-2012 at 03:12 AM. Reason: putting on flame proof suit
#89
The OP does know that there is a spring to hold the filter in position...how would that spring work if the 'big hole' was installed inward? Again, more simple logic...but whatever.
The OP did seem to get a little hot in another post asking about throttle bracket mounting screws...personality trait, I suppose.
But I digress...wait this whole thread has become a giant digression. It's silly how the most useless threads can have so much life. I guess they are entertaining.
#90
'Synthetic' oil is an extremely mis-used and mis-understood term. All of your typical motor oils are 'dinosaur oil' (not including castor oil sometimes used in two-strokes, that stuff comes from a bean). 'Synthetic' oils are made out of the same crude as 'conventional' oils, but they're much more processed to allow better control of the properties. Whether or not a 'synthetic' oil is better than a 'conventional' oil is entirely dependent on needs of the application and the specific blend of oil (not to discount personal preference and marketing).
