Oil filter
#141
Irony?
M
#142
You be the judge.
Filters are relatively cheap. Hassle??? Remove two bolts, pull cover, replace filter, put cover back on, and place bolts. It really only takes a couple minutes. I change it each filter change. Course I use the junk fram ones, so its highly import for them to be changed often.
If they'll do that to buyers of that type filter. What will they do to us?
I'm just sayin',,, ?
M
#143
OIL FILTERS EXPOSED! - Fram
M
M
#145
#147
M
M
Just sayin
#148
Unless I'm mistaken, that would be a 250 GTO?
My limited understanding of the FRAM debacle, is that they had a couple batches of filters get through where the glue holding the paper end cap came loose, and when the filter media got sucked into the bloodstream, a few engines self-destructed. This happened several years ago. What I don't understand is, knowing they would be under subsequent intense scrutiny, they continue to use the same basic glue arrangement. I'm not suggesting to anyone FRAM is trash, (and I admit to having used them in years past,) however, given their track record and knowing they have not appreciably changed their construction, I will not use them again on any of my vehicles.
