Oil Filter
Oil Filter
Did the first oil change today at 500 miles. That spring sure is a pain. Just wanted to let everyone know about the Fram oil filter that I used. I cant recall seeing it listed anywhere here, but the no. is CH6015. It even comes with a new o-ring for the filter cover.
RE: Oil Filter
Hey I found this article just in case any one was boared. Interesting stuff.
http://motorcycleinfo.calsci.com/Filters.html
RE: Oil Filter
Yup, its the exact same model number for the KLX 300, which means that KLX 300 oil filter is the KLX 250s oil filter.
I got this tip here on the forum, use vaseline to hold the spring in its place while installing the oil filter. It was a PITA when I was changing it for the 1st time until I heard the Vaseline trick
