Oil change.
Old 07-08-2008 | 05:45 PM
SnowmanSimon's Avatar
Default Oil change.
Just picked up my 2006 KLX250 about a month ago. It had 1200km's on it when I picked it up and im now at 1800. Just wondering what I should do for an oil change. What kind of oil should I be using? Anything I should know about the oil change? How much will the bike take? Id imagine there is a low/full gauge but havn't looked at it yet. Its got an oil filter as well right? I dont have very much experience with bikes so fill me in.
Old 07-08-2008 | 06:05 PM
marc11's Avatar
Default RE: Oil change.
Start by reading your owners manual, it will tell you all you need to know about oil, filters and how to change the oil. Then do a search here for any other details you may need.
Old 07-08-2008 | 06:20 PM
Xerxes's Avatar
+1. There's plenty here on oil/oil changes, even a poll on oil brands. Keep an eye peeled for references to the spring behind the filter and you'll have it covered.
Old 07-08-2008 | 08:11 PM
Sid Post's Avatar
Take some needle nose pliers and open up the base of the spring so it will stay attached to the case. Otherwise use a dab of good grease to hold it in place. Get a WIX brand filter from you local autoparts store. I think then number is something like 29244 but, look it up on this site to make sure the number is correct. Use 1.5 liters of 10-40 motorcycle specific motor oil. I'm using Castrol Octaveo (sp?) with good results.
Old 07-08-2008 | 10:38 PM
LearjetMinako's Avatar
ORIGINAL: Sid Post
+1
You're going to need a 8mm socket for the oil filter cover and a 14mm socket for the oil plug. It takes 1.5qts total with a new oil filter. Also, use only motorcycle motor oil. NOT automotive motor oil. The oil should be API SG, SH/CF, JASO MA approved SAE 10w-40 oil (it will say on the back). Finding the correct oil might be the hard part. Wal-Mart may sell it, auto stores may sell them as well. Motorcycle stores will usually carry it, but their prices tend to be higher.
Just what I use. I will be using Mobil 1 4T Full Synthetic 10w-40 w/ a Fram CH6015 oil filter. I found the oil at Wal-Mart for $5/quart (bought all of it, motorcycle shops sell the same oil for around $9-$12/qt). I change mine every 1k-2k miles (depending on how I drive).
Old 07-09-2008 | 05:58 AM
rykawasaki83's Avatar
Tommorow i too with be doing an oil change.
my only question is, is it to early for me to put synthetic in this bike?, i have roughly 170miles on the bike,and its the first oil change thats going to be done, can i switch to synthetic now? if so, is mobile 1 and ok brand? i used that in my last bike, of course motorcycle and the right type...
-ryan
Old 07-09-2008 | 11:15 AM
Personally i dont think its every too early to run synthetic.... alot of cars require it from new..... anyway, mobil 1 is ok, just make sure you get the motorcycle oil.... and 10w40...
Old 07-09-2008 | 08:27 PM
yea its what i figured as well, i ran synthetic at my first oil change with my previous bike (honda 2005 cbr600rr) and it ran beautifully with that oil. mobil 1 10w-40 motorcycle.
Old 07-09-2008 | 10:27 PM
gerrynolan's Avatar
ORIGINAL: EMS_0525
+1, Synthetic all the way.
Old 07-09-2008 | 11:07 PM
Amsoil 10w 40 Full synthetic
