O2 Sensor Installed
RE: O2 Sensor Installed
I'll use one of my microcontroller boards that I make - same stuff I use for robotics. I haven't decided yet on the actual display, probably an LCD panel initially. I may use a numeric LED panel eventually though since LCD's can freeze up in the cold. Eventually I'll also want to sense RPMs and average the sensor result vs RPM value over the course of a ride. When I get back home I can download the data and plot it to give the air/fuel mixture vs RPM curve that will tell me where the mixture is across the whole range under a variety of conditions.
ORIGINAL: Nobrakes
Do you work with any general purpose microcontroller boards, or do you build your own custom circuits? I've played around with some data loggers, but nothing too serious ... mostly "Oh look! Isn't that interesting!!!" kind of stuff.
Not only that, but it's best to let the engine stabilize under the load at different throttle openings. Exactly how long you need to allow for stabilazation I'm not sure. That's why an eddy current dyno is far more accurate than simply accelerating on an inertia drum dyno. The eddy current dyno will allow you to set various loads in order the maintain the same RPM at different throttle openings. You can go through a full range of throttle openings for every 1000RPM for example. It allows the engine to stabilize at each setting. There's no way to do that on an inertia drum unit, which most shops use because an eddy current dyno costs bukooo bucks. My bet is your bike was tested on an inerta drum dyno which only gives ball park rich/lean readings.
ORIGINAL: Nobrakes
I haven't ridden with it and from what I understand you really need to put the normal load on the engine to get a true mixture reading, just revving in the garage doesn't work, except for the idle circuit of course, but then it's just idling, not revving.
ORIGINAL: espacef1fan
any readng you get will be totally worthles unless ts a wideband..or you are ust trying to fin the afr of 14.7:1 ....time to buy an lm1
Here's a link my friend found after checking out this thread. http://techedge.com.au/vehicle/wbo2/
and another http://www.vortexbuicks-etc.com/tuni...%20performance
long story made short....unless its a wideband 02 sensor..its useles for tuning anything other than air fuel ratio at cruise...not that i'd kn0ow anything since i built my 400hp 4 banger mustang myself and TUNED myself the lm1 is a model of wideband 02 sensor made by innovate motorsports...
NoBrakes,
Sadly i second espacef1fan suggestion as I posted in your other thread. I attempted to tune a turbo car motor with the narrow band and as I stated it was only good for keeping me from blowing up the motor. It has the ability to read extreme ends of the fuel mixture ratios, rich or lean, but not the fine tuning adjustments your are hoping to do. The wide band sensor is what you need. However you exhaust bung should be able to handle the wide band sensor if you choose. The narrow band sensor uses 14.7 as its optimum on the guages, your goal for maximum power is not 14.7 but usually richer.
Having said that I'm interested to see how this works on the motorbike. Maybe you'll get lucky and it will be a benefit. Good luck and hats off to you going down this road.
ORIGINAL: Team FTB
NoBrakes,
NoBrakes,
So at this point, my O2 sensor has more or less confirmed the recommended jetting, that it's not too lean nor too rich, but definitely on the rich side of the scale which is where you want to be. And with the airbox lid in place, there is a bit of room for adjustment should I find myself at higher altitudes at some point I can pull the lid and lean out the mixture a bit. I would prefer one of those thumb screws for that, but the FCR is too tall and I don't think there is room for one between the bottom of the carb and the starter motor. If in the future I want to really dial this carb in to a very high degree, you all may be right and I'll have to bite the bullet and get the more expensive wide-band sensor. But for now, I think I'm good.
