not so common upgrades?
Old 07-03-2010 | 12:01 AM
maninthesea's Avatar
Have only had the filter installed for 450 miles so far but will clean it. It does not come apart so I plan on cleanning in diesel then soap and water then blow dry. Will take a little longer to do oil change but I think I will be happy with it.
Cheers Jim
Old 07-03-2010 | 04:51 AM
punkenduro09's Avatar
upgrades or bling?
upgrades
cams
head work
kx suspention
kickstart
chain guard (stock is weak imho)
shark fin brake guard
bling
engine plugs
drive sprocket guard
powder coating
graffics
heated grips
axel blocks
Old 07-03-2010 | 02:34 PM
wild will's Avatar
Yah, water temp is good to have.. Where'd you get that setup, wild will?
http://www.hiperf.com/acatalog/Koso_Gauges.html
Heres were I ordered it from, they had the best $.
Scroll down the page some for the temp guage, also needed is the 22mm temp sensor mount.
FYI the sensor they give you with the guage doesn't read as good as the one they give you with the mount.
The mount was the harderest thing to do, trying to make it fit in the little hose that comes out of the head and goes to the rad. I had to take some off each end of the mount to make it fit to my liking. That's were it has to go to read the right temp.
I mounted it with some velcro and it seems to stay put. The quality is good and have had no issues.
I really like the fact you no how hot things get when cranking on it and gives you a good idea when its warmed up too.
Old 07-03-2010 | 02:40 PM
wild will's Avatar
Originally Posted by FlyingFinn
Hey Will, who did the porting for you?
Looks pretty agressive port job, did you get dyno testing done before/after?
And how about that piston.
What kind of coating you have on it? "Dry lubricat" on the skirt and ceramic insulation on the crown?
Mikko
John from http://cycleproracing.com/ did the porting. I don't have any before dyno runs, just after it was done.
The piston was sent to http://www.swaintech.com/store.asp?pid=8537&catid=19694 and they silicone coated the skirt and ceramic coated the top.
Old 07-03-2010 | 04:38 PM
That sensor looks bascially like the Vapor unit. Makes one wonder if the source is the same.
Old 07-03-2010 | 04:57 PM
wild will's Avatar
Yeh they do look alike, a basic design I think.
Do they offer different sensors for oil temp, exhaust temp, ect.?
I have some silicone hoses coming and don't want to cut, so I am going to put the head temperature sensor that goes under sparkplug like a washer.
Maybe even try the oil temp, but don't know what thread size our drain plug is? Plus it replaces the drain plug and didn't like the location of it, might rip the wire right off the sensor being under the bike.
Old 07-04-2010 | 09:52 AM
slippery750's Avatar
Whelen 100 watt P.A and simulated air horn. The stock horn was not to my liking...This one really gets attention when needed!
Old 07-04-2010 | 06:30 PM
RaceGass's Avatar
One trip down a 4th gear whoopie sand wash or thru a hiway corner w/ rain grooves will make you a believer...
Old 07-04-2010 | 08:06 PM
Originally Posted by sw0ggd0gg
Pickin this up tuesday at Summit.
Alright whats the report on this puppy??? A program-able CDI would top the list for me..... details
Lots of cool un-conventional mods here....especially the cruise control....lol.
Ok, I'll toss in mine....the finger mullet starter button by Blue Sea Systems
Old 07-04-2010 | 08:16 PM
work's Avatar
Is this bike specific and where did you get it?
Quick Reply: not so common upgrades?
