Not the KLX but need help
& Like the others have said bloated battery is often a symptom of overcharging from bad voltage regulator.
So definatly change the battery and plug and then moniter the voltage with the bike running.
Cheers Jim
There may have been a short cct at the headlight connector (burned connector). This would cause a serious current draw which would prevent the starter from functioning properly (bike souldn't start), heating the battery to the point of failure (swollen battery). You would think though, that a fuse would have opened.
Perhaps pinched wires in the headlight area?
