Not getting to use High RPMs
RE: Not getting to use High RPMs
I have de-smogged. Thanks for all the suggestions. Bow season has started here in AR, so riding is limited to the middle of the day so I dont **** off all the guys on my hunting lease or in the Management Area. It is time to start spending some time tinkering. This site is such a great resource.
here's your solution, under $40 total but you'll have to act fast...
http://cgi.ebay.com/ebaymotors/ws/eB...02032&rd=1
ORIGINAL: fireroad
+2 Definatley bump the needle to the second notch and since acgill is in AR and probably at sea-level, I would say the 128 could very well get him there.
Got the 300 exhaust and header. Thanks for the heads up. I looked back at my mods and I am running the needle clip on the second notch. I am going to add the new system and I will see if that makes the difference.
ORIGINAL: acgill
With that 300 pipe you just got I was running a 125 main, stock pilot, 2.5 turns on fuel screw & the NT1C needle on the second notch. I did both the KDX snorkel then no lid at all--I liked the latter.
Something else to make sure you do is enlarge the slide hole in the carb. I think I did 7/64 the first time then enlarged SLIGHTLY to #32 when I went to the DJ kit.
I live at pretty much the same elevation.
RobWarren
07-25-2010 04:15 PM
coryhat
06-27-2008 03:43 AM
jayden
04-29-2006 10:16 PM
