Non-OEM Hand Grip Fitment Issue
Old 05-31-2011 | 05:06 PM
jglow's Avatar
Default Non-OEM Hand Grip Fitment Issue
Just put some heated grip elements on the bike, and went ahead and replaced the grips as well. I went with the Pro-Grip 714's. The concern I have is the throttle side fitment. The OEM grips have a groove in them where they slide over the ring on the throttle tube, but the new one don't. I just pushed the new ones up tight to the ring, and this leaves about a 1/4" gap - Is this okay? Here are some pics to help:
Thanks.
Jordan
Old 07-04-2011 | 03:04 PM
Default Bump
I'll be doing the same soon and noticed that Jordan didn't get any replies. I'm guessing it is not a problem, but what way ya'll?
Old 07-04-2011 | 05:59 PM
HeavyFuel's Avatar
I bought some new grips a while back and noticed the same thing. I ended up leaving the stock grip on that side (cause that's how I roll!)
Old 07-04-2011 | 11:30 PM
damon1's Avatar
I installed a set of Pro-Taper pillow tops on mine and there is the same gap. Been on for a while now and it hasn't moved. I used hairspray and wire to secure them.
Old 07-04-2011 | 11:47 PM
azdeuce's Avatar
I have the Pro Taper ones also...I used grip glue..those suckers aren't going anywhere,when they wear out cut um off..cheap2keep....mine sit flush
Old 07-05-2011 | 11:06 AM
neilapples's Avatar
I just trimmed the lip/ring on the throttle tube away (Stanley knife and some sand paper) and now all grips fit fine and go all the way to the end of the bar.
I was busting grips before, as the ends would tear after stacks because they didn’t sit flush to the end of the bar and hung out a little.
I don’t know why there is a lip/ring on the tube but it isn’t needed. My grips dont move at all and I dont add anything addtional to keep them on the bars.
Old 07-06-2011 | 09:49 AM
I put the grip heaters and those grips on my KLR. I have no idea why i waited so long to put grip heaters on. Sooo nice on those 40 Degree days riding into work.
Drose.03
02-24-2013 11:47 PM
Matasickle
04-27-2011 03:51 AM
bill622
06-03-2010 03:39 AM
Tinman
Ninja 250R
10-26-2008 02:23 AM
mikem1965
03-15-2007 03:58 PM
Quick Reply: Non-OEM Hand Grip Fitment Issue
