No rev past 8500rpm......need help
HI guys i can seem to figure out what is going on.
first i got 09 sf BB 351 with bill's carb 142 main 40 pilot .web cam 101 grind cam. and a bit of porting.
the bike is very powerfull up to 8500 when it seem to go to the rev limiter.
with the 15 tooth front gear i used to get 150kmh easy now 130max is there somthing i m missing electreonic wise.. thanks for your help
I'm trying a 137.5 main that i have on hand. I hope you guys are right . it had a 140 main that i switch because i tought is was lean...lets you guys know But to me it seemed like electrical... hope your right
If you have the air box opened up it could be your problem. Because of the internal characteristics of the carb, Bill recommends an opening size in the box. Don't remember what it was. but call him and he will tell you.
