New Vid
Old 11-19-2008, 08:20 PM
Gravy's Avatar
I'm curious what other mods you've done other than gearing. I can barely loft the front in second gear. I have to clutch it, wind it out, dump and pull hard and I might get a good 10" of air under my tire. Pretty pathetic if you ask me.
Old 11-19-2008, 08:24 PM
kgwld1's Avatar
Alot of stuff its in my sig. My gearing is way higher then stock not lower.
Old 11-20-2008, 02:52 AM
redpillar's Avatar
I gotta say I am jealous of the wrist flicking wheelies!
Old 11-20-2008, 03:40 AM
kgwld1's Avatar
Its real fun in the dirt.
Old 11-20-2008, 04:14 AM
Looks like you got her running real good.
Question thou, with the 15/40 gearing and your 17" rear (if those numbers are correct) how many rpms are you spinning at say 60 mph.
Old 11-20-2008, 05:51 AM
kgwld1's Avatar
I want to say about 5300-5400 I change hearing a lot and that sounds about right.
Old 11-20-2008, 05:55 AM
tremor38's Avatar
Yeah, that sounds about right. I'm running 15/39 with 17" rims and get close to the same result.
Old 11-20-2008, 01:38 PM
kgwld1's Avatar
Thanks tremor My tach is on the fritz (bought a new one off another member) so I Can't remember what it is at certain speeds. When I put the dirt tires on 15/47 its a wheelie beast. Its hard to keep the front end down.
Old 11-21-2008, 04:34 AM
Not bad at all.
Take about 10% off the speed and you got the rpms......wow only 6.3k at 70 mph or 7.2k at 80 mph....damn impressive with the performance you got going at that ratio.
Old 11-21-2008, 04:45 AM
kgwld1's Avatar
Yeah runs pretty good with the 13 t front and forty rear it wheelies 1,2,3,4 th gear at will 15 /40 I've got to clutch it up in 4th but i never yank on the bars.
Dirt setup its real hard to keep the front end down my buddy Pogo's himself into the ground every time he rides it. My license plate is split on both side at the bolt holes.
Kobrakriss
10-05-2010 09:31 PM
2k1w=no$
12-22-2009 05:39 AM
Worlok14
01-03-2009 08:08 PM
gotrice
11-05-2007 07:04 PM
jayden
02-02-2006 03:42 AM
Quick Reply: New Vid
