New tires, HD tubes, and rimlocks.
Old 03-06-2011 | 01:41 AM
Highbeam's Avatar
Ah, I noticed both the standard and motion pro "light-weight" rimlocks available. Not much price difference. I purposely chose the traditional cast aluminum style that is OEM for so many brands and I bet you're right that they weigh more.
I only wish I would have put the lock on my scale. I own one of those fancy gram/ounce scales that go on the counter and you can tare. I used it for the slime dose. It would have been so easy to throw those rimlocks on there and know the weight required. Lesson learned.
Old 03-06-2011 | 03:54 AM
wildcard's Avatar
As far as balance goes ... Dyna Beads /end thread
Old 03-06-2011 | 04:51 AM
With slime?
Old 03-06-2011 | 04:19 PM
ol'klx-er's Avatar
Default Yuck!
Originally Posted by IDRIDR
With slime?
I think (hope) he's kidding about Dyna beads w slime. Maybe he missed that Highbeam had slimed the tubes. Sounds like one heck of a mess if anyone falls for that advice.
Old 03-06-2011 | 05:21 PM
leftlane's Avatar
Originally Posted by dan888
I have read here on the board that there should be a dot on the new tire indicating the heaviest spot on the tire.
Check with the manufacturer. Sometimes the paint spot should be lined up with the valve stem and sometimes opposite. Just enter "paint spot" and "Dunlop" or whatever brand into google.
Old 03-06-2011 | 05:30 PM
wildcard's Avatar
With slime?
Oops... missed that part.
Old 03-06-2011 | 07:49 PM
Highbeam's Avatar
I had no idea about this dot. I've changed dozens of tires and never knew.
Old 03-06-2011 | 08:25 PM
Punkinhead's Avatar
I've been noticing more and more tires don't have the dot any more. I suppose the tire companies must be getting better at making them pretty well balanced.
Old 03-06-2011 | 09:35 PM
leftlane's Avatar
That's true, not all brands have a paint spot. It's also true that new tires, especially motorcycle tires, are very well-balanced out of the box (so to speak).
Old 03-06-2011 | 10:48 PM
armycopter's Avatar
I've never been able to get my front end to feel normal since I added a front tire rim lock. Mine will be coming off in the next week or two. I don't really think a front tire rim lock is all that necessary anyway.
Quick Reply: New tires, HD tubes, and rimlocks.
