New shift lever
I ordered that shift lever and it is longer which is perfect for me, but it is loose. The splines seem like they are a different size. I can not get it to tighten up so it does not wobble. Is yours loose?
Thanks,
Bob
I used that p/n and it fits just fine. Make sure that the gap that pinches the shaft is free of any debris/burrs as that could prevent it from pinching down on the shaft.
I have the same issue. Always loose.
Often, the little bolts aren't strong enough to pull the gap tight. Put it in a vise, and pre-crimp it a little bit to close the gap up. Do a little at a time, and test fit it as you go, otherwise you'll be shoving a flat-blade in there to open it back up. LOL
Dan
Mr. Toad
03-03-2006 05:53 AM
