new here
Old 03-27-2014 | 08:16 PM
Ockiario's Avatar
Default new here
hey everyone, i just picked up a 2010 klx250sf this week for 2400 with 1300 miles on it.. what are some of the first and cheap mods should i do first, also i bught a new clutch handle and broke the little switch that is under it..do i need to replace that what is it for?
Old 03-27-2014 | 08:20 PM
rgmr250's Avatar
The clutch switch will stop the bike from starting if you're in gear and the clutch is not pulled in - otherwise you could hit the starter button in gear, clutch out and it would move/lurch the bike forward - not very safe. If you broke the switch, I'm not certain which if the two outcomes will result - Either 1. it won't start in gear with the clutch in; or 2. it now will start in gear with the clutch out - depends on how the switch works (normally open or normally closed etc.)
Old 03-27-2014 | 09:17 PM
cmott426's Avatar
It is normally open when the clutch is out. Makes contact when the clutch is pulled in. With the switch broken it will only start in neutral. you can bypass it, connect the two ends together. But like rgmr250 said it will start in gear with the clutch out.
Old 03-27-2014 | 09:43 PM
Brieninsac's Avatar
Congrats on the new bike. Sounds like a good deal. As for mods, what are your expectations and budget?
coopers2k
09-01-2008 07:20 PM
GeneralPatton
07-29-2008 03:49 AM
Too~SweeeT
05-08-2008 01:08 PM
MAD KAW
05-23-2006 09:00 PM
Bonafide
04-16-2006 08:21 PM
Quick Reply: new here
