New Bars installation problems
Old 07-24-2008 | 03:09 AM
GoGreen's Avatar
Default New Bars installation problems
Has anyone had any trouble putting new bars on their bike? I put a set of pro taper SE bars on and I cannot got the handlebar switches back on right. Am I missing something? Also I had to cut the barpad off because the mounting bracket wouldn't fit with it on. I'm bummed. I thought it would be an easy job like it was on my KX125.
Old 07-24-2008 | 03:21 AM
RaceGass's Avatar
Look inside the switch housings where they contact the stock bars, the stock bars have a hole on each side. There is a nub that goes with the hole in the bars to prevent the switch housings from spinning on the bars.
Trim off that little nub and you should have no problem.
Old 07-24-2008 | 03:30 AM
lcpl0331's Avatar
what he said.
Old 07-24-2008 | 04:01 AM
RaceGass's Avatar
The second part of your question I don't quite understand. I put on a pair of pro taper universal fat bar mounts to install the 1 1/8" bars, as they certainly wouldn't fit the stock handle bar perches (which are for 7/8" handlebars).
Old 07-24-2008 | 04:20 AM
GoGreen's Avatar
Thank you for your help RaceGass. I don't know how you could put different bar mounts on without changing the top triple clamp cause the bottoom bar mount is built into the top triple clamp.
The mounting bracket would not fit with the barpad on so I took the bar pad off. I don't know if the barpad is supposed to fit on there real tight or not but I cut it with a utility knife and I'll have to fenagle it back on somehow. Cheers
Old 07-24-2008 | 04:43 AM
RaceGass's Avatar
Here is what I had to use to mount 1 1/8" bars.
Old 07-24-2008 | 11:27 PM
GoGreen's Avatar
How do you keep the switches from spinning around on the bars? The switch housing is the only thing that holds the throttle on! That's pretty lame of Kawasaki to basically try to force you to use their crappy steel OEM bars.
Old 07-25-2008 | 12:41 AM
GreenMonsta's Avatar
After grinding the nubs from inside the switch housing I easily replaced my crappy bent OEM bars with crappy 18$ aftermarket bars. The switches don't spin under normal riding but if ya crash it's good to have em move instead of braking off.
EMS_0525
01-30-2007 02:17 AM
TrailRider
08-02-2006 12:11 PM
Marcus33
03-23-2006 12:24 AM
zx6d
11-17-2005 08:30 AM
Banzai
10-05-2005 10:16 PM
