Needles pic
Old 01-10-2012 | 05:07 AM
Originally Posted by brooksie
Not sure why the KLX300 needle would be needed unless you bored, ported, camed and removed the air box. The small adjustment most bikes require to open up flow should only require a shim under the stock needle to help under revs. That, along with moderate jetting changes to main and pilot should be enough. Most bikes are usually geared a little poochy to get them through testing, too. I'd go down one tooth on the CS once you get your jetting right, but that seems like an awfully small sprocket to start with. Looking forward to hearing how your efforts turn out.
It's more than just lifting the needle. The DJ needle has a better taper design that's much better than the stock needle.
Old 01-10-2012 | 05:37 AM
brooksie's Avatar
I hoping that the stock needle gets the fuel mix into a better place than it was. I'd go back to stock components and check everything, like he's doing. The air box and plug looked soaked with fuel. Every bike seems different when it comes to tuning.
Old 01-10-2012 | 05:44 AM
the N1TC is not the same as the DJ.
The DJ (dynojet) needle has a much more aggressive taper.
Old 01-10-2012 | 10:13 AM
I assumed that, i was curious on the lengths.
Old 01-10-2012 | 03:00 PM
They're not that different to create the horridly rich plug condition shown in his pic. I almost think he may have something else going on.
Old 01-10-2012 | 03:18 PM
Default Stock and DynoJet #2206
Not the best pic, but here is my stock and DynoJet #2206 needles for reference.Needles pic-0420112144a.jpg
Old 01-11-2012 | 12:04 AM
I'm not sure, but, I think compared to the N1tc needle, the extra length down at the point of the other needles doesn't come into play. What I mean is that if you were to measure down from the clip/washer/(whatever the needle rests on in the slide), you would find that the diameters of the needles are similar. There has to be some difference in the diameters, but not as drastically different as the lengths may lead you to believe. I'm guessing that the longer end of the stock needle never comes into play. I don't believe that the end of my N1tc needle ever comes completely out of it's metering hole in the throat of the carb, even with the slide fully opened.
Make any sense?
Dan
  #28
Old 01-11-2012 | 04:28 AM
Make any sense?
Dan
You wouldn't expect it to come out of the metering hole, or it could get tilted and not go back in. My carb is on the bench. Maybe I'll check next time I'm in the shop.
  #29
Old 01-11-2012 | 10:12 AM
Make any sense?
Dan
I was kinda thinking that. Like how long it is doesn't really matter, does the needle ever really "seat" into anything. I think its more about the diameter of the hole it goes through and the diameter of the needle in specific locations, the taper.
  #30
Old 01-11-2012 | 03:15 PM
Ranger Ron's Avatar
Do you know the diameter of the straight section of the DJ needle? If so, would you mind posting it?
Thanks,
Ron
