Need info on handguard install
RE: Need info on handguard install
ORIGINAL: Rabbit
why dont you just use a tap and cut threads into the end of the bar? Then all you have to do is screw the bolt in it should take you all of 10 minutes. Thats what i did. It was easy
Thanks,
db
bars, handguard, handguards, install, installation, installing, kx100, problems, renthal, throttle, tube, tusk
