need help with flat spot after exhaust mod
after gutting out my exhaust there is a slight hesitation at the first few mm of throttle. Once i pass that point the bike runs smoothly. If i restrict the flow of air from the exhaust with my hands, the flat spot goes away completely. How can i solve this issue without patching up my exhaust. I like the noise
Hey man i dont know. I only know that my carb is a mv30p
www.minerva.co.id/index.php/products/detail/8
Totally stock and i know nothing about carbs. If you know anything about my carb please tell me how to fix it.
The carb is running lean from the factory as is. Even before a mod, a re-jet is usually advised to make the bike run correctly. By gutting out the exhaust, you have made this lean condition even worse. You will definitely need to re-jet.
Is jetting expensive? Im just wondering what specifications to ask for since i have no idea whats in there now?
Thanks anyway, i now have an idea what to do. Gonna ask the dealer about it. Do you think that while im at it i should also mod my air filter box? Could this improve the performance further? It is highly restrictive and im just wondering if it will help if i remove the cover which is under the seat. It never ever gets wet or too dirty in there so i think its safe to do so.
