Need help deciding guys!
So I'll be driving up to South Carolina in 2 weeks to look at and trade for the 09 if all looks well! I can't wait, going to be a long 2 weeks!
If you are going to do any off-road with it, change out that front tire. That is the most likely reason why the shroud is broke. The less wheel travel really doesn’t affect me. I have yet to bottom the front and I have tried. No, I don’t do large jumps but I do get some air and hit some fairly square edges at times. I took a tie-wrap and put in on the lower leg, went for a ride and the tire wrap was still about 1-2 inches from bottoming out. I have bottom the rear out. But it has a nice bump stop so it isn’t too bad. If you do find the need to, there are after marked springs and re-valves. The 09 has compression clickers on the forks but no rebound or air bleeder like the older models. The Shock has both compression and rebound on all years.
This is just my theory....since the 09 has less rear wheel travel but uses the same shock and spring rate (correct me if I am wrong), that equals to a stiffer suspension then the older models.
Seems strange they didn't add air bleeders on the forks? I will be revalving and springing the bike to my weight later, for now I'm just going to enjoy it
Thanks for all your replies and help!
Paul
Been there, done that ....................a few times
These shrouds stick out quite a bit.
Hope all works out well with the trade.
Dan
Dan
I'm ready to start farkeling the bike to get it personalized and to get back to the trails which I've been missing more than I thought I would.
Paul
jimbo59153
05-22-2007 04:17 AM
